pss inboard shaft seals
kmarine
I have a 1995 Wellcraft Martinique 3600 with Pss shaft seals. The shaft diameter is 1 1/4 inches and the through hull tube measures 2 3/32 inches. The pss boot comes in 2 inch and 2 1/4 inch sizes. These are the original brand of seals on the boat. Does anyone know which size to order? I have measured this three times with two different calipers. Thank you
Bt Doctur
Re: pss inboard shaft seals
tube is just a bit over 2 and 1/8th,so I`d go with the 2 inch ones.
