Re: PTFE or Teflon to mount bracket.
Thanks Longline, I was going to use aluminum but seen bunch of guys using thick 1" thick teflon plate. Teflon is strong and not as rigid as aluminum so I thought it might better spread the load, especially on the inner side of the transom where the fiberglass may be bumpy and uneven. I will definitely do the double nut thing and huge washers though.
Thanks!
