PTT assembly removal - Yamaha C80 1997
FrizFreleng
Motor is tilted up and all bolts removed. Assembly slides up about an inch and stops. I am trying to remove the assembly out the back from the bracket. Do I have to unbolt the bracket and motor from the transom and remove it forward?
Thanks, Friz
Capt Ken
Re: PTT assembly removal - Yamaha C80 1997
You will need to support the engine and remove one side of the transom bracket
FrizFreleng
Worked like a charm Unit is on the work bench.
Thanks for the help. Friz
