If I had the appropriate length of bolts, can I use the same puller to pull the bearing cage out that I did to pull a flywheel off?
seems like it would work...its a 1992 Johnson 25hp.
also, do you have to have the gear shaft pulled out to pull the bearing cage from the lower unit.
