Pulling Engine
Drifternz
Hi guys, just getting ready to pull my mercrusier 165 inline 6.
Would pulling on two points be sufficient or should i use 4 points?
achris
More fish than mountain goat
Re: Pulling Engine
I prefer a spreader. That way the load on each lift point is vertical, and doesn't put any bending load on the lift points.
fat fanny
Re: Pulling Engine
As achris said safety 1st! This process may seem simple to most but will jump up and bite you when you least exspect it.
Re: Pulling Engine
remember the engine hoist will test the tensile strength of everything you forgot to disconnnect.
Ryanlewis2010
Re: Pulling Engine
oh boY u said it my 4cyl snapped my swing set in half which was 2 big 8x8 timbers so make sure you use something that can hold it pulling a motor out can be rather simple just stay out from under the lift structure.
Drifternz
Re: Pulling Engine
Thanks for advise guys,Im lucky as im a dairy farmer and have access to a large
tractor with front end loader.Will post some pic,s when i start.
achris
Re: Pulling Engine
I work offshore... We have a motto.... "Look up and live"...
Re: Pulling Engine
ok, let me rephrase. the front end loader will test the tensile strength of everything you forgot to disconnect......:D
achris
Re: Pulling Engine
Ok... Let me rephrase..... The last vessel I worked on had a main crane SWL of 1,200 tons... That will lift the entire boat!!! :D
