pulling engine
green76
93 Baja islander...4.3 vortec v6 mercruiser alpha one ...have to pull engine to change that y pipe...what will I need? Any tips or advice? Best type of cherry picker to buy? Any advice will be much appreciated!! Thanks in advance and HAPPY BOATING!!!!
Don S
Re: pulling engine
Here is a .pdf file to get you started.
It's not mentioned in the file below, but remove the lag bolts from the front motor mounts and leave the mounts on the engine. You MUST have an engine alignment bar to verify alignment when you put it back in.
View attachment #18 GM V6 93-97 Bal Sft 82.pdf
green76
Re: pulling engine
Awesome!! I love this site!! I have no boater friends to consult with so I really do appreciate the help!!
