Ok So I have a 1981 Glastron SSV-177 with the Mercruiser 165 I6, or gm 250.... I have never had this boat running. I bought it as a project with very little information except that it seems to have very few hours. Less then 100 according to the hour meter.
I have low compression on a few of the cylinders and I pulled the head to check on things. I searched all around and cant see any cracks in the block or head. Manifold seem ok too. I drained what it had for oil and there was water in there. Also two of the combustion chambers looked quite dirty. My guess is water was sitting in there for some time. Not sure how long though.
Anyway I plan on pulling the block from the Glastron in the next few days. Even if the block is good it will need to go to the machine shop. My question is weather or not I should un bolt the engine mounts from the bilge rails or should I leave the mounts and unbolt the engine from the mounts? I know alot of people pull them with the mounts so they don't have to do an engine alignment. The FSM also states this. What do you think? how hard is it to do an alignment? I mean ive read the procedure and I can either purchase the tool or create one (have a lathe at work and plenty of material) but if its a major PIA and I can avoid it then why not?
Thoughts?
Thanks for any advice!
Thoughts?
