I am going to pull the motor in my boat tommorrow to check the back of the block to see if it is split or a soft plug pushed out. My question is wouldnt it be easier to undo the base bolts on the front mount and pull the front motor mountwith the motor. If I did it that way wouldnt it stay lined up for the shaft from the outdrive to stay lined up when I put it back in?
