Greetings!
Ok, so I am ready to take out my motor. You can have a look at the link to my project for pictures as to why. I have some questions about how to go about this. It seems easy enough but..considering what is at stake I'd like to make sure. I'll number them for the sake of reference.
1) Taking the lower unit off seems to involve 6 bolts plus the 2 on the lift/trim. I have built a stand for the lower similar to ones seen here. Do I need to take both sides of the lift/trim units off so each side hangs loose? or is just removing the bolts attached to the lower enough? (everything needs to come out so I can redo the transom)
2) Where do I lift the engine??? I have seen pictures of folks with engines hanging from hoists but have honestly never paid close attention to where the chains ran underneath. I am worried about putting a good portion of the weight of the engine on something that should not be bearing weight and damage something. I really don't need more problems at this point.
I'm going to rent one of the big engine lifts so I don't try to do something silly like chain it to a tree and have it break the tree and the engine.
3) Any other tips, tricks or things to watch for?
Respectfully,
-T
Respectfully,
-T
