pulling prop
bspeth
My buddy has fishing line wrapped all up in the prop.Honda out board with all the controls.I am not too familiar with outboards. Should he just put it in forward and take off the nut,or does he need to ground out the coil to prevent starting?Thanks-Blair
Sea Rider
Re: pulling prop
Remove kill cord lanyard from switch. Remove prop nut, take prop out, remove trapped fishing line, grease prop's shaft splines with marine grease, put back prop and nut, torque well and voila. If fishing line is not removed could end damaging lower unit oil seal.
Happy Boating
wrench 3
Re: pulling prop
You can also put the engine in neutral, place a piece of wood between a prop blade and the anti-cavitation plate and then remove the nut. Keep the block of wood towards the center of the plate, were it's stronger.
bspeth
Re: pulling prop
thanks,i will let him know
