Re: pulling the outdrive
Put helm in foreward. Take off the two bolts at the end of the trim cylinders. Remmove the trim ram. Remove your zinc, 3/8" allen. Remove allen key under zinc 5/16". Remove 6 nuts 5/8". Drive should slide off, (with help of course). If you can put the skeg right on the ground, or wood, with drive all the way down, it will help with the re-installation of the drive. You really should get a merc. manual for your alignment issues, (among other things). Get an alignment tool. Hope this helps.....J
