Pulling to left
I have a Friend that has a center console fiberglass boat. It's about 22ft long 115 Yamaha on it. When he takes off runs strait plains fast. Runs great at wot still strait. When the throttle is dropped it pulls to the left. We are totally baffled why it would do this.
thumpar
Re: Pulling to left
Does it have a fin anode on the drive? It may need adjusting if so.
tazrig
Re: Pulling to left
Hull could be slightly out of shape.
Texasmark
Re: Pulling to left
I just answered this on another thread. On some hulls depending on speed and trim position, you can have a steady helm or one that pulls. If you have a sensitive situation, set the trim tab, rear in the direction of the helm turning, amount is to push the rear to that side till it quits pulling where you run most of the time; aka speed and trim angle. At other positions then you could have pulling.
The incorporation of a "zero feed back" helm can help to reduce the problem. Teleflex-Morse makes them. May sell them on this site.
Mark
ziggy
Re: Pulling to left
^, yep, i'll also add to ''aka speed and trim angle" load...
the attachment is a visual as to how ya adj. the trim tab.
Re: Pulling to left
Thank you for the help and info. I know I posted this a while back forgot about it. I was on vacation totally lost track of everything.
