Re: pulling wire off #3 plug
When I was having issues with my Prestolite system, I tried moving just the trigger leads. I theory it should work. For some reason, I can't remember all the details because I did so many things...but my tests were inconclusive. You can try it by just moving the trigger leads and see what you get.
If no difference, swap all the wires (trigger, stator, coil) between the 2nd and 3rd CD module. If the problem moves, then I would suspect the original CD module for #3 and 4 cylinder is bad.
One other thing, the stator leads should read 680 - 850 ohms between the blue and yellow or brown/yellow and brown/blue wires depending on year.
