Re: pulls to right after trimmed out
It depends how much you're trimming up. If it's not an extreme amount you can adjust the trim tab on the motor (the little fin thing behind the prop). Loosen, rotate a bit the appropriate way, re-tighten and then test drive. If you're trimming it way up, then I think the trim tab becomes relatively ineffective. Usually you can fine adjust the trim tab so the pull isn't extreme at normal speeds/trim.<br /><br />---edit---<br /><br />beat to the punch!
