Pulse limiter has check valve?
dingbat
The manual says that the pulse limiter has an internal check valve however I can blow right thru mine in either direction. Is this normal or is the check valve stuck open.
Time for a new one?
1997 200 Hp Ocean Pro
R.Johnson
Re: Pulse limiter has check valve?
The limiter protect's the pump from a sudden, or violent rush of air, such as from a back-fire. It is more of a metal diaphram then a true check valve. Being able to blow through both end's is normal.
hookedonjc
Yeap I had the same question a while back. R.Johnson is right on
Dont Ever Give Up
