Pump mounted fuel filter
minion
Has anyone here tackled changing the Fuel pump mounted fuel filter? I have a 98 3.0LX engine and there is a filter in the BOTTOM of the pump.Just found that out last fall!!!<br /> It has a lockwire and screw clamp holding it in place. I have not touched this filter since new.Figure it's time for a change.<br />
Laddies
Banned
Re: Pump mounted fuel filter
Minion, nothing to it the new filter will have a new gasket with it, the wire it simple a safty wire to prevent the screw from coming lose and should be replaced also
rodbolt
most hulls its easier to remove the fuel pump. be vary careful loosening that screw thats holds the filter cup on. if ya break it the bail is not avalible seperately.<br /> if you have access though it can be changed with the pump in place. there is a spring that you will fight as well.
minion
Thanks All...<br />I can access it on the engine.<br />the pic above is from laying on my side and "Looking" @ the pump. Should I remove and plug the fuel feed or just leave it?<br /><br />Thanks in advance
Don S
One thing about that filter, it is not a water seperating filter. Your best bet after you change that filter is to install an aftermarket (Racor as an example) fuel filter/water seperator. Then you shouldn't have to worry about replacing that fuel pump filter, just the spin on on your filter seperator.
minion
Good point Don and I have a perfect place for such a filter .<br /><br />Thanks !
