clockwatcher
- Joined
- Nov 8, 2009
- 289
I have a Merc trim system, single bolt through the bottom of the plastic reservoir, 1990 350Mag. The system had a lot of water in it (white milk). I rebuilt the cylinders, clean with new seals. Now I want to purge the pump. The pump is on the bench.
Can I fill the reservor with new oil and run the pump into a bucket without the lines attached, or will I blow parts out of the hose ports?
I just want to cycle the old oil out before I install it back into the boat.
