Alumarine
- Joined
- Feb 22, 2005
- 3,738
Hi there,
I did a search on "purple and voltage" and read through 7 pages without finding an answer.
I was installing a temp/oil pressure alarm under my dash and was checking voltages.
I've run the black lead of my tester to the negative post of the battery.
On the BAT terminal of my ignition switch I have 12.5 volts.
On the IGN terminal with the purple wire I only have 11.6 volts when the key is in the run position.
I disconnected the Purple wire at the alternator with the same result.
When I disconnect the Purple/Yellow and faded Pink??? from the positive side of the coil the reading on the IGN terminal goes up to 12.4 volts.
The Purple/Yellow and faded Pink??? wire are crimped together on a ring terminal that looks factory.
Is this normal? The boat runs perfect and I wasn't looking for trouble.
thanks
thanks
