I have a 25 hp electric push button (mounted on side of engine housing). Good battery, but will not start when I push the button. Will crank and run when I use the pull start.
1, Can I use a Ford solenoid on this motor (4 terminal)
2. Can't jump the solenoid, completly dead. I did change the battery, new one fully charged hooked up to it.
3. When I put a hot wire to the starter side and the small terminal the starter kicks in.
4. Is there a safety switch or rectifier that might be bad?
5. Where can I get an OEM manual for this motor?
Thanks,
George
Thanks,
George
