Re: put new in bord 351 w in but can't turn it over
It sounds like the engine is frozen.<br />I would do everything said previously with one exception, <br />1.remove the sparks plugs and spray DW40 into each cyclinder and let soak over night.<br />2.Then try turning the crank shaft with a breaker bar clock wise, if it turns, keep turning a few times, Make sure the engine has oil.(you might want to prim the engine by removing the distributor, mark the settings,timing, with a drill.)<br />3.If this makes the engine turn, your in business.<br />4.Check the electrical to insure you have spark if the starter will crank.<br />5.If the starter doesn't crank remove it and test it separately with a battery. If it cranks slow with a good battery rebuild the starter or get a new good, the bushings and brushes are probably bad.<br />6.Install the starter and crank it, if it cranks and won't start, chech the secondary ignition coil, cable, cap and rotor.<br />Good Luck.
