Puter clock
SpinnerBait_Nut
Ok, now what causes the clock on the ol computer to loose time?<br /><br />I set it at 9 and at 12:18 it said 11:51.<br /><br />Now that is 27 minutes in 3 hours.<br />What gives?<br />Old age? :D <br />This is on a 4 year old puter.<br /><br />Thanks
ob
Re: Puter clock
Don't feel alone SBN.My computers clock runs two hours early.I reset it and when I turn it back on the next day it's back to two hours early.I'm sure I'm a computer retard but I don't know what to do to change it.I reset it and it reads right until I shut down the dang thing and the next time I turn it on ,it's exactly two hours early. :mad:
SpinnerBait_Nut
Re: Puter clock
That's just it ob, mine is never shut off and looses it.
flashback
Re: Puter clock
Spinner, I have read somewhere that there is a battery that keeps the clock going and when this battery is on its last legs, the clock may slow down. take this with a grain of salt, as I am dumb when it comes to puters.......
gsbodine
Re: Puter clock
The clocks on x86 motherboards are notoriously bad. There is no good way to make your computer clock keep time correctly without syncing it to a real timekeeper occasionally using a network protocol specifically designed to do this (NTP). <br /><br />There are lots of freeware clients that do this for you (Non-Windows machines usually have them built-in on default installs), but I will warn you that many of them also have spyware attached. <br /><br />My favorite is a very small program offered for free from NIST (really the atomic clock people in Boulder). Here is the link to it: <br /> http://www.boulder.nist.gov/timefreq/service/its.htm <br />You can try others as well. Just let it set your computer clock occasionally and you will be about as accurate as you can be.
Re: Puter clock
Originally posted by ob:<br /> Don't feel alone SBN.My computers clock runs two hours early.I reset it and when I turn it back on the next day it's back to two hours early.I'm sure I'm a computer retard but I don't know what to do to change it.I reset it and it reads right until I shut down the dang thing and the next time I turn it on ,it's exactly two hours early. :mad:
I'm not a puter guy... but have you checked what time zone your puter is set at? Since it only does it at boot up. Just a thought and probly not a very good one.
Formula1974
Re: Puter clock
thats the first thing I thought about also link since it is always 2 hours sounds like a time zone thing.
Re: Puter clock
^Bump^ Wondering if it really was the time zone. :)
SpinnerBait_Nut
Re: Puter clock
Don't know what it was Link, it is now only 2 minutes slower than my other puter now.<br />Go figure.
ob
Re: Puter clock
Originally posted by Link:<br />
I'm not a puter guy... but have you checked what time zone your puter is set at? Since it only does it at boot up. Just a thought and probly not a very good one. [/QB][/quote]<br /><br />Well ,you're a puter guy now Link. :) My clock was on Pacific time.Duh... :p Didn't even know I could select a time zone.And,there was a bunch on the list.All is working fine now.Thanks a bunch,puter guy. ;)
SpinnerBait_Nut
Re: Puter clock
Just checked and it is only 1 minute behind my other one now.
Re: Puter clock
OB:<br />It was Formula1974 who figured it out ;) <br />OK Spinner then I'm throwing in with MY. It's your Lil' Green Buddies messing with ya and your puters clock decimal point! :D
SpinnerBait_Nut
Re: Puter clock
It is 1 minute behind now so all is good again.<br /><br />I told them to quit messing with my mind like that.
