1986mariner150
- Joined
- Mar 13, 2004
- 142
Hey folks and thanks for looking at my post. Some of you may have seen another post about a 200XP I was considering. To make a long story short I stopped by another marine dealer on the way to pick it up and bought a 130 HP boat there. I have heard many good things about OMC V-4's through the years and had read some posts from another poster who was considering a 115 so I didn't feel totally blind going in. We tested compression all between 140 and 150. Ran it on hose and it took it a little while to idle but I think he flooded it. Appears to not have been used to much or been worked on as all the bolt heads look untouched. My question is if I do the de-carbon process listed in the FAQ where you use 3/4 gal. gas:1/4 Seafoam should that clean the carbs as well? The boat's last registration sticker was an '02 which probally was bought in '01. I don't feel I have any stuck rings with the compression readings. I am going to change the gear case oil first thing in the morning. What am I forgetting?
