Re: Putting on 4" center riser man. to 3" y pipe. Mercruiser 260
most "custom" work is nothing but trial and error. taking measurements, adapting things from your own creativity. i personally adapted a set of BARR center rise exhaust manifolds and risers, which were designed for omc exhaust, to my mercruiser 5.7L. i had to buy 3" bulk wet exhaust hose to go from my risers to my elbows, to get the right length, and then bought a pair of 4"x4" bellows between the elbows and Y pipe. it took a bit of research, and using non typical parts, but is not impossible. i do caution tho, if you ever decide to sell the boat, keep track of what parts you used, even part numbers are best, so that the new owner won't have a headache trying to figure out what you did. good luck
