nabeel.alsalam
- Joined
- Jan 4, 2005
- 37
My 1990 Johnson 40 hp has developed an ignition problem. It starts easily and idles after a warm up period. However, after I drop it into gear and increase the throttle it will not develop any power or go above 2000 rpm. <br /><br />What Ive done so far:<br /><br />1) I hooked up a timing light to spark plug wire #1 and the light strobed and the timing seemed to be correct. I hooked up the light to spark plug wire #2 and the light strobed about 180 degrees out of phase.<br /><br />2) Looked at plugs: Top one is dry and tan colored. The bottom one is wet and gray. <br /><br />3) Took the spark plugs out and connected the plug wires to a home made spark plug tester. Both are jumping the required 9/16 of an inch while the engine is cranking.<br /><br />4) With the plugs removed and grounded and the wires connected, I verified that they are sparking. They are but I was not impressed with the quality of the spark.<br /><br />5) Replaced plugs, started engine with fast idle up a bit, and pulled off the primary wire to the upper coil for #1 cylinder. Engine dies. Repeat and pull off primary wire to the lower coil for #2 cylinder. Engine continues running with no change in rpm! <br /><br />6) I reverse the primary and second leads of the coils. I pull off the primary lead to the upper coil for #2 cylinder and the engine continues running with no change in rpm. I pull off the primary lead to the lower coil for #1 cylinder and the engine dies.<br /><br />From #2, #5, and #6, I would conclude that Im running on 1 cylinder and something upstream of the coils is the problem. <br /><br />From #1, #3 and #4, I would conclude that both cylinders are getting spark. <br /><br />Im worried about the contradictory information. Does this happen? Why? (Im not experienced with Johnson engines, outboard motors, or 2-cycle engines).<br /><br />What would you suggest as my next steps? I certainly will make sure the primary wire for cylinder #2 that leads from under the flywheel to the lower coil is in good shape (the part that I can see without the flywheel removed looks good). Assuming it is, is there anything else I can do to isolate the problem? Im guessing that a bad charge coil would affect both cylinders. Im also guessing the ignition module is expensive, so I hate to replace it without being fairly sure that is where the problem is. <br /><br />I'm trying to develop Zen with this engine but it is lonely (time consuming and expensive) work. I really appreciate the help you provide.
