Pvc repair question
bullet33
Does anyone know if PVC can be glued with 5200? That crap can be virtually unremovable.
TOHATSU GURU
Re: Pvc repair question
It's the equivalant of using a hammer to drive in a screw. It may work for awhile, but in the end it will let go and you will never be able to get the material to correctly accept the proper glue/repair.
jacoboregon
The proper glues are well proven and not expensive. They are also not too tedious to apply correctly.
As tohatsu stated, once it lets go you are pretty much finished.
If you have a needed repair do it right using the right material and never worry about it again.
