not sure if the rings or pistons r bad i'm doing a compression test on it tomorrow and i will know what it is hopefully but here it is the engine sounds fine but once it's warm the oil starts to leak from the oil dipstick just a bit at idle there is a breather hose that goes from the carb to this black box im just wondering is it pluged or is there anything else i can do before i know i have a bad piston ring? the oil is new so it was not milky cause i didn't want to run it for long but when i pluged it with my hand the pressure went to the oil cap and when i took my hand off the fumes came froom the dipstick so now u know the bad now i just hope there is a better solution..thanks guys any suggestions or tips will help a lot .
