Qd-17 10hp
Chinewalker
Re: Qd-17 10hp
Which parts? Basic tune-up stuff is available right here on i-boats, at your local Johnrude dealer, local NAPA, etc. That would include coils, points, condensers, carb kit, waterpump impeller, lower unit seals, etc.
As for gas tanks - poke around your local marinas. Most have a few tucked away somewhere, even if they don't know it. Showing up at coffee time with a box of donuts may help get you in their good graces enough to allow you to peruse the junk piles, back sheds, lofts, etc.
Also, try eBay, Craigslist, AOMCI.org, etc.
Rich Weaver
Re: Qd-17 10hp
Thanks for the Info. I plan on going to the Marina's this weekend to look for the tank. It seems to me that the pull start spring broke and it was taken apart and newer fixed. So all the parts associated with it are missing with the exception of the mounting bracket. I pulled the plugs and it looks like the motor was running good when it broke. I plan on putting the motor on a 16' Duratech aluminum boat and using it to fish with at Jamestown RI. Am I crazy?
Thanks Again
Rich
