Hey All, My first post to the forum, been looking around for a while.
I have a Johnson QD-20 motor that ran last year, but I could not get it to start this year. I decided to rebuild the carb and update some of the ignition components based on the threads here.
After removing the spark plugs I noticed one, the top one, was used, but the bottom plug looked brand new - bad coil probably.
I ordered the parts, and started to disasemble the carb and ignition components. I just need a little help with the ignition coils. When I took the old ones off the plug wires just kinda fell off, they looked broken. I haven't received the new coils yet (possibly tomorrow or Monday for arrival). How will the plug wires connect to the coil?
Also, I'm going to regrease various area's that look like they need it (bottom of armature plate, throttle gear areas, etc.). What type of grease should I use?
After I reassemble the carb, is this the correct method of adjusting the fast/slow idle adjustments?
http://forums.iboats.com/showthread.php?t=167352
Thanks in advance.
Ryan
Thanks in advance.
Ryan
