Howard Sterndrive
- Joined
- Nov 5, 2008
- 4,603
I gotta think the common idea that a QJet's smaller primaries somehow give better economy is not supported by fact.
Been doing some reading about BTUs, BSFC and how much gasoline it takes to make HP.
Many points of the interwebs seem to agree that if you take a carbureted pushrod engine and measure the gas flowing to it in GPH, you can multiply that number by about 12 to figure out how much HP you are making at the crank.
Seems to work for my motor. I burn 16 GPH @ WOT...which is 192HP and my V6 is rated at 185HP.
So at cruise, I'm burning 5GPH at 27 mph/3000 rpm......=60HP... yeah.. seems about right
Is there any way higher air velocity through 2 small venturis can make the engine more efficient?
Because that's all I can see would be different from a QJet to a 2 BBL....faster air through the throat....
