Then all you have is the fuel line, throttle linkage on the port side and the choke rod on the starboard side, don't lose the little clip that holds the rod that is hooked up to the choke coil in place. When you remove the fuel line that goes into the big nut that holds the small filter in the front of the carb, use a big adjustable wrench to hold that big nut and use a brake line style wrench to avoid rounding off the flats on the fuel line fitting. This way only the fuel line unscrews from the big nut not the whole thing that retains the small fuel filter.
When you reinstall it, check the thick gasket on the manifold if it is deteriorated you might want to replace it. I like to thread the fuel line fitting into that big nut before tightening the mounting bolts because it allows you to move the carb slightly if needed to get the threads started without stripping anything.
Some have 4 bolts, 2 up front and 2 in the rear, some use 2 bolts up front and a stud and nut in the rear. DO NOT overtighten the bolts/nuts when reinstalling, that is what warps the air horn on Q-Jets.
After that you have to set the idle speed and idle mixture, check back for how to do that.
