Re: Quantity of Gear Oil
Should be 22 OZ if your engine is 3 cylinders. Otherwise 22 will be close. I have a 90 3 cyl and that is what the book calls for in it and they are almost the same engine. WW has it in the quart, Quicksilver Premium with a pump, hose, and fill adapter. Oil is recommended and the accessories make it a walk in the park.
If you have the 3 cyl engine, you should have 3 plugs into the LU. Drain obviously on the bottom, probably has a magnet in it and probably has a few iron filings....that's why it's there. Just above the AV plate are 2 more screws just like it. Open both. Fill till it starts coming out the front hole, let the big bubbles pass and plug it with a new or gasket in good shape. Continue filling till the rear vent has oil and the big bubbles have passed. Plug it in a like manner. Remove the fill adapter and insert the screw likewise on the gasket. You will loose some fluid but try to minimize it. Engine should be vertical while filling.
Mark
