Question about a new motor install
mattsanders
I just put a 1977 70 hp on my 15 foot Kingfisher. The old motor was a 1971 50 hp. My 50 would push my boat at 27.2 MPH WOT. The 70 is only pushing it to 34mph WOT. Should it be faster? This is a light boat, and the Skeeter we took it off of was heavy and was running in the 36mph range. Setup seems perfect, same 17 prop.
5150abf
Re: Question about a new motor install
You need a tach to set up the new engine, outboards run to an RPM not a speed, you need to find out what RPM it is doing now to know what prop you need.
7 mph for 20 more horse doesn't seem to far off really, there may be more there btu you need to know where you are with your current prop.
emdsapmgr
Prop size will make a big difference in performance/speed. That should be propped to run 5500-5700 rpm top end. Make sure you don't have the engine mounted too low on the transom excess causing drag.
