Question about Eagle Fish ID II
MajorPainage
Hey folks. New here and hope this is allowed. Haven't come across other forums to ask.
So we have an old Eagle Fish ID II and we had a mouse over the winter make a nest and chewed through the transducer cable. So I am wondering where one would purchase a replacement. I can't seem to find an Eagle website so not sure if they are out of business or if they are just hidden. I see Bass Pro Shop sells replacement transducers but have no idea if they are compatible. Appreciate any ideas.
mr 88
The cable can be spliced back together. I believe Airmar make a coupler/ splicer for that.(30-35.00) wires are all color coded I used one recently and it works flawlessly .
MajorPainage
That's likely the only option. A used one isn't worth $60-80. Better invested in a new unit.
mr 88
If the cable is easily accessible you could just solder the wires back together. They are a very small diameter so trying to put terminal ends on them may be a challenge vs small wire twist / solder / actual coupler made for it.
MajorPainage
Yea it's mounted on the electric trolling motor so everything is exposed and easy to work on.
mr 88
Airmar Splice kit , Google that and I see them.from.19.00 and up .I would stick with the Airmar brand.
Grub54891
You can splice them. You “ might” loose a bit of tuning but most of the time you don’t. I have the same unit, still working 20 plus years later.
dingbat
If it’s not in a wet location, splice it back together with Scotchloks.
Simple and easy to do.
TyeeMan
Eagle fish finders were/are made by Lowrance. Try the Lowrance web site, see if you can contact someone there.
