I am putting a closed cooling system on the 5.7 Chevy I am building. I am using Mercruiser center rise exhaust manifolds which will be closed cooled also. The Mercruiser parts breakdown shows only gasket 27-863725 is used to block off the water passages between the manifold and exhaust elbow.
I am not real comfortable using just the gasket material. I am thinking more about some sort of metal block off plate sandwiched between two gaskets.
Any thoughts.
Any thoughts.
