Hello. I am starting to go through winterizing my boat and motor. I have read the FAQs about winterization, and fogging procedures. Is it ok to use 2 cycle oil to fog with or is actual fogging oil the only thing that should be used? The motor will be stored outside, and the winter temps are usually anywhere from 25-0F. Also, I am planning on rebuilding my carbs this winter, and I would like to know if there would be a problem with storing the motor with the carbs removed?<br /><br />Thanks.
