Ok, I was replacing some wiring on my boat. And all of my gauges were working except for the tach. I removed all the gauges to clean all the contacts and make sure I had clean connection. When I was replacing the gauges, I noticed that my voltage gauge did not work anymore. I was getting power to the gauge and had a good ground. I could not figure out why the gauge wasn't working.. Then I was told by a older guy that if I tighten the center bracing nut to tight, it will peg the needle. (Its raining here now can't test the theory). But wanted to know if anyone heard anything about, if you tighten the center nut of the gauges in the instrument panel to tight, it will peg the needles and they won't work.
