smallblock
- Joined
- Sep 5, 2009
- 57
Hello, this little two horse has set in my gararge for a few years unused. The times I did use it, it ran like crap so it got set aside. Im finally tackeling it and have pulled off carb to start. It has a low speed adjustment and a high speed adjustment. My question is should the nut be tightened all the way in? The upper was in all the way,the lower was in only half way. Also where is a good place to start on these adjustments. In the past I have turned all the way in,then backed out one and a half turns. Just not sure because I have never had two to deal with. One of them the washer or packing is ok, the other is deteriorated. Can I use something else for this material? I just dont want or need to order a complete carb kit just for this, everything else is cleanable...Thanks, any suggestions will we appreciated very much.
