emoney
- Joined
- Jul 19, 2010
- 2,551
Changing out an impeller, I removed the drive shaft and sat the lower unit
against my tool bench and walked away. Came back to find that it had
tipped over and about 4-5 ounces of fluid had spilled out (on the positive
side the fluid was nice and fresh looking). I understand it takes about a
quart to fill it. So, does this mean I need to go get a pump and a quart
and add some, or is this a small enough amount to not worry about?
I ask, because don't I need to change out the gaskets on the two screws
when I add/change lower unit fluid? If so, does anyone carry them for
a 1983 Chrysler 50hp or are they the same as some other, more current
motor that a dealer might stock?
