Question about my 1984 2hp evinrude
2mate
I was just wounderin on my evinrude 2 1984 model i am never sure if it is cooling enough.
I have a manual for the eninge but dosnt really explain all i really see as cooling is a little bit of spray coming out of the four holes on the leg.
Recenlty i took the leg of and gave it all a good clean and waterpump was fine :confused: I am not sure if this is as it should be or if maybe somthing is wrong?
Any help will be apriciated
2mate
F_R
Re: Question about my 1984 2hp evinrude
That's the way they are. Most of the spent cooling water goes out with the underwater exhaust. All you see is what just happens to blow out those holes.
Make sure your pump impeller truly is "fine" and don't worry about it.
2mate
Thanks for your help i think i will change the water pump just to be sure do you know where i can get a new one before thursday next week?
Vic.S
In the UK www.WillsMarine.co.uk in Kingsbridge, Devon are apparently good for mail order spares.
www.outboards-direct.co.uk (Oakley marine) in Brighton came up trumps for someone recently
www.outboardservices.co.uk in Lostwithiel is another I have a note of.
Must be an agent in Kent somewhere, used to be couple in Chatham, try Yell.com Let us know if you find anyone local.
Try asking on UK forum like www.ybw.com/forums someone might know of agents in Kent or East Sussex.
How about Highway Marine in Sandwich
BUT if you have water spraying out and not steam you have no immediate problem.
2mate
It seems to be mostly water but some steam i think
