I recently aquired a 1984 Wellcraft 23' Aft Cabin, 260 Merc Alpha 1.
Let me detail the battery system as I see it:
The boat has two batts, one appears to be a dual purpose starting battery, the other appears to be a deep cycle "house battery".
There is a (bank1, bank2, both, off) rotary switch.
There appears to be a 60amp isolator bolted down by the engine.
The boat has a 110v AC system, I have found a distribution panel, but have yet to find the inverter/charger. Any advice on where this may be located would be great, it appears to be all factory installed equipment.
As the system stands I assume I have bank 1 for starting, and bank 2 to run the DC systems without engine power (and for additional gusto if needed to start), am I interpreting this system correctly?
If I am correct I would like to add an additional deep cycle in series with the current deep cycle batt. This would give me two deep cycles on bank 2 and my starter battery on bank 1. I just want to have a good line of power to run my lights and other basic equipment without engine power.
Any problems you see with this system? Or any advice in general would be great. I spent a good amout of time just learning what was in the boat. Everything is very neat and appears to be done right.
Thanks guys,
Ryan
Thanks guys,
Ryan
