Hi - I'm fixing a leaky port light. Have removed and will clean up surface before reinstalling. Before I reinstall, I am considering filling the existing screw holes with thickened epoxy and then drilling and tapping new holes before I screw the port light back in.
My question - If I fill the existing holes, at the current size, will the screws grab when i drill and tap? Or should I bore out a larger diameter hole to be filled with thickened epoxy - so the hole i drill and tap is all inside new hardened thickened epoxy? This section of the hull is solid fiberglass, no core.
Also, best filler to use in thickening the epoxy? I am using West Systems.
Thanks.
Thanks.
