Question about Quick Start?
When you set idle timing on engines equipped with QS do you have to ground out the temp switch telling the CDI engine is warmed up? Thanks.
archcycle
Re: Question about Quick Start?
Is just letting it warm up an option?
boobie
You can do either but it has to be out Q/S to set idle timing.
Faztbullet
Boobie is correct and I myself set up all the timings at lake so engine has back pressure. I made a test prop and can turn 5500 rpm on the trailer.
SparkieBoat
I would love to see a pic of that test prop Faz
boobie
I'd bet it's a prop with the ends of the blades cut off equally to a certain point.
