rhillman75
- Joined
- Jul 28, 2010
- 176
I have finally have had an opportunity to get everything fixed from the previous owner except for this: One thing I have really noticed about the 3000 side commander is that when it is put into either reverse or forward there is quite a bit of resistance that I have kind of just gotten used to "gentle" nudging her forward ever so gently. I did get chance to look at it tonight and here is what I have noticed...I don't know what to call it technically but it appears to be a "shock" mounted in line beside the drive cable. When I completely remove it and just have the cable on the posts there is zero resistance and shifting is really smooth. I also noticed that there were a couple of different washers like someone played with it before. From what I can see and the current attachment is like this: from the armiture I have the double threaded bolt, then a spring that goes on the bolt, then a flat washer, then the barrel connector for the drive cable, then the "shock". Shouldn't there be a washer between the barrel and the "shock"? I know when I tighten the double ended bolt in place it seems there is to much rubbing and alot of tension when the commander goes into forward or reverse. Pictures are included...
