Question about telltale hole...
Rocky4052
This is a 1966 Merc 500 50hp 4 cyl. I'm trying to clear line to tell tale hole. I'm using weedeater line and got it to go in just over a foot, but no further. How far should that line go in? Will I be able to access it from below when I change the impeller? I have the prop in a barrel of water right now, and tried compressed air thru the hose from the top and there was no air coming out the bottom [no bubbles] so I am assuming it is really blocked. I'm waiting for my manual to come in before I tear anything apart. Any info would be greatly appreciated. There seems to be very knowlegable people on this site more than willing to help out! Thanks, Dan
tashasdaddy
Re: Question about telltale hole...
thats as far as the weed eater line will go. when you drop the lower you can use a water hose and try to flush from the water tube. i believe your engine does not have a thermostat. the rule is no pee no cool. the pee line is the last in the water circuit. the engine fills before the water gets to the pee outlet.
Rocky4052
Tashasdaddy............That's just what I wanted to know. Thank you--Dan
