Question about using epoxy resin with 1708 cloth?
Status
Not open for further replies.
bzajdek
I have read that epoxy and mat (CSM) are not compatible because of the glue that holds the fibers together. What are some peoples experiences using epoxy and biaxail mat? Second question if it is acceptable to use 1708 with epoxy what type of finishing cloth can be used besides CSM. I only have limited experience with polyester resin and none with epoxy resin.
Re: Question about using epoxy resin with 1708 cloth?
Ayuh,...
I've never had any issues with Any cloth when using Epoxy....
The scattered strand matting used for Poly, doesn't Need to be used with Epoxy...
Not that you couldn't if you needed alittle bulk,.. But there are other, better choices...
oops!
i think someones fibbing on ya !
we have forums full of epoxy-csm-1708 laminating
as far as a fininshing csm is not the best product.......try a thin veil type cloth....wallmart or home depot sells it in small packages....it finishes really smooth.
you can see it here........
http://forums.iboats.com/showthread.php?t=234392
page 81 post 2021
BillP
You are missing some details but mostly on the right track. The difference with mat in 1708 (or any biaxial) is it doesn't use a chemical binder that needs dissolving...the mat is stitched and is 100% compatible with epoxy or poly.
Standard mat is NOT compatible with epoxy. The binder will NOT fully dissolve when using epoxy and the mat will NOT fully saturate. Poly resin has styrene, which is what dissolves the binder to let the resin saturate properly. Epoxy doesn't have styrene. However, there is an epoxy compatible mat available. It's not as easy to find. I order it.
Also, leaving mat out of the layup equation is an engineering error if stiffness is needed. Getting stiffness without using mat will end up in a massively thick and heavy layup or labor intensive stringers and structures, etc. Its something they learned back in the 1960s and is why mat continues to be a prime part of all boat layups for the last 60 yrs.
BP
bzajdek
Ok, I think I understand after the first layer of 1708 you would need a mat like cloth between the next layer, but if a second layer of 1708 is used the mat stiched to the back takes the place of not having multiple layers of heavy cloth bonded straight together. Thanks for the replies.:)
BillP
No matter which resin or glass cloth you use, it's always applied by alternating mat/cloth/mat. So when using biaxial you always put mat surfaces against the glassed surface and the next layer of mat against the cloth. Mat does several things. It makes better bonding to the surface and gives better peel strength between layers of woven cloth...and it provides stiffness. Some say you don't need mat with epoxy but that goes against all engineering standards for frp. The same lamination (in oz weight) with mat is stronger in peel strength no matter if poly or epoxy. Flexing causes laminations to peel so stiffness is another redeeming factor of mat.
Mark42
BillP hit the nail on the head regarding the binder in CSM. The CSM in the 1708 is STITCHED on, not attached with a binder/glue. So there is no issue with using epoxy.
If you are using epoxy with 1708, there is NO NEED to add a layer of CSM between layers of 1708. That is wasting money. The 1708 has its own layer of CSM stitched on, and that is all that is needed to make a good bond with the layer below.
A 6 or 8 oz cloth will make a nice finishing layer. I found that rolling on a thin layer of epoxy on the finished 1708 layup made a nice smooth surface ready for sanding. I didn't use a finish layer of glass over the 1708.
You will be amazed at the strength of 1708 and epoxy.
erikgreen
BP
A couple things I'd like to correct here. First, "epoxy compatible" mat is uncommon nowadays because almost all currently sold mat is epoxy compatible. It used to be that mat binder dissolved in poly resin only, but I think you'd have a hard-ish time finding mat that won't work with epoxy. For example, the cheap Bondo mat sold wherever Bondo poly resin is sold is epoxy compatible. Mat is attached to 1708 cloth because 1708 is designed for use with poly. You can also buy biaxial glass cloth without the mat in 17 oz. weight if you like.
Second, you don't need to use mat with epoxy, period. You can use it with any resin if you want to save money, and mat is needed with poly to help glass properly adhere to eg. a wood surface, but it's not a requirement.
Mat has been used in pro fiberglass boatbuilding because it's cheap, and because you need to use it with poly in some cases. There are many high end boats built using hand layup of woven fabric and epoxy with zero mat or chopper gun used. Mat and chopped fiber are cheap ways to build up the thickness of a hull, that's why they're used. They're not superior in strength or stiffness to woven cloth layups in any way.
Stiffness of the final composite is dependent on thickness of the total layup and the fiber used (e-glass vs. kevlar vs. carbon fiber). Stiffness of a hull (as opposed to a flat piece of glass) is greatly affected by shape and support structures (stringers/frames).
Skip the mat if you want to when using epoxy. You'll add more strength using woven fabric or biaxial for the same weight of glass.
Erik
BillP
Erik
Not one of those "corrections" are accurate. They are however, good examples of why people should do their homework with product mfgs documented specs and frp engineering specs to get accuracy.
1.Standard mat is not epoxy compatible.
2.Epoxy mat has always been more difficult to find.
3.1708 has mat for engineering (stiffness) and adhesion reasons...for poly or epoxy resins.
4.Stiffness is not dependent on thickness unless you want high weight.
5.There are not many, if any at all, high or low end boat mfgs that don't use mat.
Bill P.
erikgreen
"Standard" is a relative term. If you consider Bondo mat from the local home store or "Sea Glass" mat from West Marine standard, both are epoxy compatible. You can still find mat that's not, sure, but it's a shrinking minority of the market, because it's cheaper for manufacturers to make mat with just one binder that works with epoxy, poly, and VE resins, rather than to make one for poly and one for epoxy. This has been the case for about 10 or so years.
By the way, I'm not going to pick up the bait you're trolling with the comment on "why people should do their homework"... I encourage the various readers of this board to look around this board, read up, and do their own research, then decide who to believe :)
It was when it first came out. It's not now.
Stiffness is dictated by the thickness of the layup, and thickness depends on how much glass, mat, and resin you use, so I suppose you could say that you add mat to add stiffness, because it adds thickness. But it's always weaker than adding a similar weight of woven fabric.
Epoxy needs no mat or anything else for adhesion assistance. Think about it, when have you ever seen carbon fiber mat or kevlar mat? You haven't, because those fabrics are used for high end boats (with epoxy) and mat isn't needed. Mat is used in low end boats because they're made with poly, which is cheap, and mat is a nice cheap way to add bulk to a layup.
Mat stitched to biaxial fabric is very easy to handle, and coincidentally forms most of a "ply" or standard fractional thickness of a hull. Most hand laid up hulls use an alternating series of 2-3 (or more) "ply" layers, so the layup schedule goes something like this, outside of hull to inside:
gelcoat->surfacing veil->mat->fabric->mat->fabric->mat->roving
I won't speculate on stitched fabric/mat uses outside the boat building industry, but I'd suspect it's a lot easier for anyone working with glass to use a stitched combo like 1708 than multiple separate pieces of mat or fabric, it's stronger than chopper gun layup (which is easier to build), and cheaper than using fabric only. Plus as mentioned, if you use poly, you need the mat to make it all adhere.
Stiffness is dependent upon two things: Total composite thickness and the properties of the skin layers of said composite (tensile strength and elasticity). It's a requirement that the core of the composite have sufficient shear strength and crush resistance to hold the skins (inner and outer) together and force them to bend in unison, but that's not a hard goal to meet. You can make a solid panel of glass, essentially using the same glass/resin mix for the "core" and "skin", but the core doesn't take any more stress than a lighter material used in its place. It's just easier to build, and heavier.
A given thickness of hull made of solid poly with mat, woven, roving, or a chopper gun will have about the same stiffness as the same hull section made with plywood core covered with a couple layers of woven cloth. Probably the composite sandwich will be stronger, and it will certainly be lighter. There's a pretty good discussion of hull cores here, with some interesting info if you want to read:
http://www.powerandmotoryacht.com/boat/hard-core-facts/
Bill P.
Here's links to a couple:
www.cigaretteracing.com
www.fountainpowerboats.com
Once again, mat is used because it's a cheap way to make a hull thicker. The only cheaper way is with a chopper gun, which is even weaker. If you need strength and/or don't care about price, you use epoxy and glass, aramid, or carbon fabrics, not mat.
Erik
jonesg
"Once again, mat is used because it's a cheap way to make a hull thicker. The only cheaper way is with a chopper gun, which is even weaker. If you need strength and/or don't care about price, you use epoxy and glass, aramid, or carbon fabrics, not mat. "
that is my understanding, mat is the fallaparticle board of the glass world.
It has its uses. I prefer to use various weights of cloth unless theres an absolute need for mat.
Epoxy and exotic fibers are best for strength and lightness.
But I'll take cheapo poly and cloth most days.
For laminating slightly uneven surfaces together, matting is a better choice.
Its all fun stuff, if it ain't fun, why bother.
BillP
Well, I now understand you rely on web site message board postings to get your facts. I don't do it that way. By the way, I shot an email off to BONDO to see what they say about their mat and epoxy...did you happen to learn it is epoxy compatible from them, a message board or presume it is compatible? That would be "A", "B" or "C". Anyway, you want proof? Come on over to the West Marine I used to work at part time...bring your poly and epoxy resin...I'll provide West Marine mat and an epoxy mat. Learn what saturation compatiblity is and isn't. I've done this before...have you? If you don't want to visit Florida, start surfing mat supply web sites and see what 99,.999% of them post about mat compatibility with epoxy. Don't confuse binded mat with stitched mat either. Mat for epoxy isn't common...never was and still isn't. PM me and I'll give you the wm store number so you can contact the store mgr (Eric) and ask if Bill P is real.
Stiffness? If multiple laminations of woven cloth were the end of it all there would be no use for foam sandwich, coremat, fabmat or mat. Total strength of many laminations to get required stiffness is usually overkill in tensile strength and too heavy...thus core or mat. You evidently have only a partial understanding of the engineering properties of mat to believe it's only used for "cheap". Mat has value you don't know about. Along that topic, are you saying two layers of 24oz woven roven epoxied together have the same peel strength as ones using mat in between them or "enough" strength to do the task? "A" or "B"?
So you're taking this to the elite of the elite race boat category...where they are usually massively overbuilt to handle wave jumping at 100+mph. Fountain and Cigarette boats use bi/tri/quads and it's hand laminated. So are you saying they use no surfacing mat? Or saying they use stitched cloth that has no mat? Are you saying they use extra lamnations or extra structure to get stiffness? They don't say which and I'll believe there isn't one oz of mat or surfacing veil (carbon) in their boats when I see it published by them or on a lamination schedule.
There's no trolling here...I suggested people do research with the mfgs who make products so they will know fact from message board fiction. I know what is and isn't correct and don't expect it to be taken at face value by anyone.
bp
Mark42
All I can add is that this past summer I had a very hard time finding epoxy compatable mat. Every time I called the supplier, they said the matt they carry was not epoxy compatable. I ended up using 1708 with epoxy.
I can tell you this: One layer of 1708 and epoxy is absolutely incredibly strong. Way past what ever expectations I had when laying it up. Put one layer on each side of a piece of foam, and what you end up with is just amazing.
jcsercsa
Hay guys I just went and checked out USComposities web, site an they say poly and vinyl resin !!
Fiberglass Mat
Chopped strand mat is very economical and offers good stiffness. However, for greater strength
and a lower weight product biaxials and woven cloth fabrics are generally used.
All the following mats are compatible for use with polyester resins and vinyl ester resin.
http://uscomposites.com/mat.html
John
BillP
This is what uscomposites says...and it's the same word spoken everywhere mat is sold.
TIP
-The individual fibers that make up chopped strand mat is held together by an adhesive binder that is designed to break down in polyester and vinyl ester resins.
1-1/2oz Epoxy Mat
Chopped Strand Mat compatible for use with epoxies.
Material is stitched together, as opposed to
the adhesive binders used in common fiberglass mats.
jonesg
If someone could donate a case of epoxy I'll sort this all out.:rolleyes:
Ayuh,.... Probably because it isn't Needed....
Ain't It,..??
I use epoxy,+ cloth,... No mat....
I've Never had a lamination come apart,... Even when I Tried.....
BillP
Here's the response to the email I sent 3M on their Bondo mat the other day:
Bill,
Thanks for contacting 3M,
The Epoxy Resin will not completely disolve the binder on our fiberglass
mat.
Regards
Wayne Banks
3M Bondo Technical Service
800-421-2663 X 4
3M Automotive Aftermarket Division
www.3m.com/automotive
Mark42
Bill,
mat.
Regards
Wayne Banks
800-421-2663 X 4
Not completely disolved binder means not completely encapsulated fiberglass strands, means a weak product.
erikgreen
Bill,
mat.
Regards
Wayne Banks
800-421-2663 X 4
As I said, you can still find mat out there that is not epoxy compatible. Thanks for proving my point :)
With regard to the West Marine you used to work at, it appears things have changed some since you worked there. For reference, here is a good source for info on West marine "Sea Glass" mat... the West online catalog:
West Catalog
In the overview section, check out the first bullet point.
I'm going to answer back a couple of your questions here, Bill, since you asked nicely.
Neither... re-read my posts. To re-phrase what I said using your 24 oz example, a panel made of two skins of 24 oz. roving covering a core of eg. 1/4" balsa will be exactly as stiff as two skins of 24 oz roving laminated to (on either side of) a 1/4" thickness of mat and resin. The mat effectively forms the core, and adds no strength, and is much heavier than the cored panel.
They don't generally publish lamination schedules, but if you read about and/or see video of their manufacturing processes, you won't see mat. Except for surfacing veil sometimes, which you are correct technically is a mat product, but it's far from the type of mat you're describing as having "stiffness properties". To be crystal clear about "what I'm saying", I am saying their boats use no mat in structural settings, but rather use fabric, stitched or otherwise, laminated over cores, or else solid construction using fabric which is machine sprayed with resin and vacuum bagged.
The reason I mention the high end boats is that it supports the point I've made all along. Mat is used in a lot of boats because it's cheap, and in boats where cheap doesn't matter, epoxy and fabric are used, period. Cheap boats have mat, expensive boats generally don't.
Frankly, I wouldn't bother. West Marine salespeople are great at knowing what products are out there, and they can order in anything you need, generally. At a large mark-up, of course :) But I've yet to run into any West Salesperson I'd consider an authority on boat design and manufacture... it's just not their job.
Sorry Bill, although you seem to have a lot of self esteem invested in your answers here, some of them just aren't right, and it doesn't matter how long you've been sure of them. The information you're giving is still wrong.
I have far too many sources to list, but the chief ones are books, job training, chemistry courses, the Internet (vendor pages) and yes, forum posts. A long time ago I learned to cross-check information, and verify information given on forums by reading vendor documentation and printed references... that's why I recommend the same for folks here. It becomes obvious quickly which posters are knowledgeable and which ones are repeating back information they've believed for 20 years because some "old expert" told them so, back when they worked at ye olde boat shop.
FYI, posting that "you talked with XXX and they said you were right" isn't a proper reference format.. it's too open to interpretation. Instead, post links to web pages that no one in the public has access to alter stating information that supports your point. That's much more useful to everyone here, and useful information is why we post to Iboats.
Erik
Status
