Question about Volvo 3.0 exhaust manifold
Tstew
Good morning. I have the exhaust manifold off. I’m replacing the gasket and manifold itself. Any other maintenance items I need to do while this is off? My first time doing this. Also, does anyone know torque specs on the manifold and head bolts? I’d appreciate it. the manifold is leaking and bubbling gas where it meets the head is reason for replacement .
first, welcome aboard
find out why it was leaking. if this is a salt water boat, your manifold most likely needs replacing.
181 CID/ 3.0L Torque Specifications
DESCRIPTIONLb. In.Lb. Ft.N[SUP].[/SUP]m
Camshaft Sprocket Bolts80 9
Connecting Rod Cap Nuts 4561
Cylinder Head Bolts 90 (Note 1)122 (Note 1)
Distributor Clamp 2027
Marine Engine Coupler to Flywheel 3547
Flywheel Housing to Block 2128
Flywheel to Crankshaft Bolts 6588
Front Cover Bolts30 3.4
Front Mount to Block 2128
Main Bearing Cap Bolts 6588
Manifold to Head 23 (Note 2)31 (Note 2)
Oil Pan Bolts-Crankcase80 9
Oil Pan Bolts-to Front Cover45 5
Oil Pan Studs to Oil Seal Retainer or Crankcase15 1.7
Oil Pump Cover72 8
Oil Pump to Block120 14
Oil Pump Pickup60 7
Rocker Arm Cover and Bolts40 4.5
Rear Crankshaft Oil Seal Retainer Nuts135 15
Spark Plugs 2230
Starter Motor to Block 3750
Timing Gear Cover72 8
Torsional Damper Bolt 5068
Water Pump to Block 1520
Tstew
Thanks Scott.
its a freshwater boat.
the manifold was cracked on bottom from previous owner not winterizing it. I’m trying to get the boat and engine sorted.
Tstew
Thanks Scott.
