tumblebug1949
- Joined
- Jan 14, 2013
- 76
First off, let me identify my engine. It is a 1999, 40hp, two cylinder Force motor. It does not have a tale tell water stream that shows you the impeller is pumping and water is circulating but instead has a small spout on the top cylinder which a hose connects to going to a pressure gauge on the instrument panel. I may in the future split this line to provide a tale tell stream.
I bought this pontoon during the winter and put it in a large tub of water today before I trailered it to the lake for the first time. I wanted to get it in the water and run the motor some to just get used to how it handled. Before I went, I decided to put it in a trashcan full of water and start the motor before I hauled it all the way to the lake. I put it in water and the water level was well over the water intake holes. I removed the cowling and cut the small hose leading to the pressure gauge. That way I would have water squirting out if the pump was working. I started the motor and let it idle but there was no water coming from the small outlet. I let it run for a couple of minutes until the cylinder head was warm to the touch but you could still lay your hand on it. Still no water. Then I shut it off.
Here is my question. Is it possible that I did not have the motor low enough in the water. The water level was right at the cavitation plate. On this motor, there are exhaust slots just above the cavitation plate right above the small trim tab.
These were not in the water. I think I did not have the motor down in the water enough. I think the water level needs to be a few inches above the cavitation plate for the water to reach the pump housing. (((Let me know if this thought is correct.)))
I am sure the impeller needed to be replaced anyway but if I ran it with out water getting to the pump housing, I would need to be rebuilt even if it had been new.
The seller told me he bought the pontoon from his brother who bought it new in 1999. He said he did not think the impeller had ever been changed so I had already bought a pump rebuild kit so I was going to change it anyway. I just wanted to put it into the lake for a quick test to make sure everything worked. Well, I did not get to the lake but will now be replacing the impeller first.
Any constructive comments would be appreciated.
Tom
Tom
