John Wilson
- Joined
- May 30, 2001
- 7
Hi everyone.<br />This is my first post here and already I'm asking for advice.
<br /><br />I have an 1987 85 HP Force on a 15ft Glastron. I've had it since it was new and it has worked well for me until last fall. It started having proiblems shifting into forward gear and it would grind and then THUNK! Reverse was better. Adjusting the linkage did not help. This week I took it into the dealer and the news was not good. It seems that a bearing or 2 went in the lower unit and took some gears out with it. Bottom line is that the lower unit needs to be replaced or rebuilt. My options are:<br /><br />Brand new for $2500<br />Buy a rebuilt unit for $1800<br />Have dealer rebuild for $1400<br />Buy a USED unit with 30 day warranty for $950<br /><br />I was told that my Force is worth about $750 for parts or $300 as a whole BEFORE it went south. I'm trying to figur if it is worth it to fix or trade for a larger engine. The same dealer would take my motor(worth $750) plus $2900 to get me into a very good condition 1992 Johnson Pro Series 90hp V4 with power tilt/trim, installed. I know this weighs more than my Force but basically has 20 more hp. I primarily use the boat for waterskiing and my skiers are in the 160-210 lbs. range. The Force does an adequete job but deep-water starts are an exercise for the heavier skiers.<br /><br />Sorry this is so long but what I'd like to get comments on are the following questions:<br /><br />Is it worth it to fix the Force and if so what option seems like the best value?<br /><br />If I went for the Johnson trade, is this a motor I should be considering? Is it reliable and will it give me a performance boost?<br /><br />Can I get more for my Force as a parts source? The powerhead and tilt/trim are in great shape.<br /><br />Thanks in advance for all comments/suggestions. I'm really in a quandry about this.<br /><br /><br />------------------<br />John Wilson<br /><br />Timing is Everything
