QUESTION FOR 12 FOOTER
lonewolf5347
QUESTION IS THIS THE RIGHT OR WRONG WAY TO CHECK COMPRESSION?OUT BOARD ENGINE REMOVE THE PLUGS FROM ALL CYLINDERS ALSO REMOVE PLUG SPARK PLUG WIRES.CHECK EACH CYLINDER ONE BY ONE.WILL THIS WAY BLOW A STATOR? THIS WAS SOMETHING THAT WAS OWN MY MIND. ;)
Bob_VT
Re: QUESTION FOR 12 FOOTER
12Footer's #1024 Do a search under his # on this forum. I am certain he will still reply but I am trying to give you an edge ;) <br /><br />Ton's of compression check subjects have been covered. <br /><br />Good question though! Also be sure to hold the motor at WOT during the check to have the butterfies in the carbs fully open.<br /><br />Bob
