DHPMARINE, You told someone in another thread :
I wanted to know how to check the fuel pump to see if the diaphram was ruptured? I have done the plug wire test and have a dead cylinder. In a three cylinder engine how does it flood one cylinder and not all of them?<br /><br />Thanks<br />-TRDoes this engine have VRO ? If NOT the regular fuel pump can rupture its diaphram,and flood one cylinder,and keep it from having any power output.But it will usually run when not in gear. Can you get some insulated pliers and remove one plug wire at a time?If one cylinder is dead,this could be the cause.<br />
